I haven't seen this done before. How is this achieved as the USB clock is usually a multiple of 12MHz but the audio clocks aren't?With the MDAC / FDAC the USB Microframes will be locked to the Audio Master clock so will not generate non synchronise noise.
Here's Archimago's measurement of this 8KHz noise spike using a Teac UD 501 which uses the TMS320 DSP chip for USB receiver duties done in software. Admittedly the 8KH noise spike was found when using this configuration HTPC --> 10' generic USB cable --> TEAC UD501 DAC --> 6' balanced analogue cables --> Emotiva XSP-1 preamp --> 6' balanced analogue cables --> E-MU USB0404 ADC --> measurement computerI've only seen the 8KHz frames on USB devices with poor clock recovery (Non ASync) such as Tenor, TI PCM290X / 270x and Cmedia.
It seems like the Emotiva preamp caused this noise to be measureable on the analogue outs of the preamp but it does show that the 8KHz noise is internally generated in the DAC from the PHY logic gate noise pattern when dealing with the USB micrframes
Hi John, sorry if this had been asked and answered.
Can the detox USB 1.1 and 2.0 ports be used at the same time?
Eg USB 1.1 connected to MDAC while the USB 2.0 connected to MDAC2 (while playing a WAV file for example)?
What is the input? USB port type B?
Thanks.
On the FDAC we use a PLL circuit to derive the USB clock form the Audio master clock, while the MDAC has a clever Clock circuit.
The 8200Cd does not have a clock output port but you will still gain the other benefits - especially galvanic isolation / RF attenuation and the spread spectrum clock feature.
I don't think you can fit dsd 64 (2.8mb/s) into 24/96 (2.3 mb/s)Great, OK so perhaps I haven't fully understood, but is 96kHz 24 bit enough bandwidth to cope with DSD, or is that limitation only for PCM?
see
http://dsd-guide.com/dop-open-standard
I think John is saying it's limited on the USB1 port, but not on the USB2 port, unless I've misunderstood again
Ok, sounds interesting, thanks. So the PLL derived USB clock comes out as a better option Vs a separate standalone USB clock - interestingOn the FDAC we use a PLL circuit to derive the USB clock form the Audio master clock, while the MDAC has a clever Clock circuit.
Yep, I agree on both counts but I do still pause for thought - if we are to follow the logic of the premise that mistiming or jitter of the USB datapacket timing makes it's way into the DAC then the idea of the packet timing itself making it's presence felt in some way within the DAC is not that outrageous. Not necessarily as a direct translation of the microframe timing into a 8KHz spike noise on the analogue output, however!This should not be taken as a representative design!!! - as I designer I'm horrified that you can see the 8KHz USB frame packets on the audio output!
Don't worry, you can't see it on the outputs of either the emotiva amp (ie the ordinary stereo output) or Archimago's teac dac. There doesn't seem to be any reason to blame the dac. It only seems to arise from the av bypass output of the emotiva. Given that it's effect on the av is dramatically reduced with the corning we may wonder where exactly it is produced, from where it is radiated etc. Are we hearing noise direct from the computer or noise radiated from the usb receiver in the dac? Could it be radiated by the usb cable and picked up by the emotiva's analog circuits?On the FDAC we use a PLL circuit to derive the USB clock form the Audio master clock, while the MDAC has a clever Clock circuit.
This all sounds very good guys but I'm a bit concerned that nobody has yet mentioned the dilithium crystals . . . . . .
Very interesting, so even though jitter is not improved upon past the usb, its the effects from async processing that radiates upon itself. This seems very similar to the effects from the likes of the mdacs firmware differences. It would seem that discrete dacs would be the ideal way to prevent such issues as you could isolate such effects.The incoming USB Data is varying in time around its expected "time slot" the frequency and amplitude of this time variance is the encoded phase noise. When the USB device in the DAC processes this data it radiates this noise into the system.
Just to be clear for myself and others, the jitter reduction from the detox is not to improve on jitter itself for the converted signal but to prevent radiated noise modulation from the async usb process. Infact wouldnt the output signal have identical jitter pattern once processed by the async usb.The Detox prime reason for exsistances is to attenuate the "unwanted" RF and Jitter pattern of the incoming USB Data, provide a low noise PSU and also offer a galvanically isolated USB 1.1 output.
Yes an optically isolated "Clock Locked" SPDIF source is the the perfect solution, but only for single sample rate applications as you are left with the problem of how to command the sample rate change / Master clock rate change. Worked well in the days of 44.1KHz CD only systems but not in our modern multi samplerate world.
Thanks john for the reply, you answered most of my curiosity so appreciate as always your time.
I suppose thats why people clock lock their cd players with dacs. Makes sense somewhat.
