Steve,
Yes no problem - I have a couple of dead AC adaptors I can scavenge the lead from.
Thanks for that - I'll ask again later in your design phase what the ideal voltages and current capacity needs to be to support a potential L2 + L4 combo.
Steve,
Back to the MDAC2
Does anyone see input voltages lower then 15.2V?
+14.9V in Finland. MDAC Premium Fusion. -1.0V difference to jarip. Hmm...weird.
Hmm, thats on the low side - I'll have to modify a PSU for your MDAC2, Please remind me when we are in the process of shipping your unit.
You should mention the low voltage to your electricity provider... ATM, you are waiting longer for your tea to boil
I believe that the Transformers are the same for the UK & European versions...
Try the MDAC connected to the power regulator and read its voltage.
John,David,
Did you use XLR's and between your MDAC and the Roksan pre-amplifier in the system? I'm pondering if you used the XLR connection with the Roksan and its shorted one phase of the MDAC's XLR output?
You have not used an "odd" XLR to RCA lead or some such have you?
Hi John,
RAW MDAC supply voltages in Chorley, UK.
Lowest seen over 24 hours:
Unmodified unit 18.0v
TOY unit 17.0v
Highest seen over 24 hours (at 01:00 local):
Unmodified unit 18.3v - (is that a record?)
TOY unit 17.4v
Yes, I availed myself of an ex-display donor unit. I couldn't let that work you did, slaving through the night, go to scrap.
hello! what is the link of the upgrade firmware for mdac ?what is the firmware more natural and balanced?
