Here are some more projects made to order that I've been completing;
This time a tonearm board for Jazzbones' Techi but in a different wood than ebony;
Can you guess what it is?
Rough face off and recessed
Dished
Fitted out for Linn arms
(in flash it looks like this - its not that dark)
In warmer light like this
Still final rubbing down and polishing to go.
As for the wood. It's African Blackwood. Slightly more dense than Ebony and harder. Nice grain to it.
One more for BobC of the warm to go under his amazing plinths
and an ongoing bass horn project: 1.2m exponentials that will be fitted out with a 15" bass drivers.
Designed and modelled this to give optimal performance 80Hz to 400Hz. This will be part of a 5 way system.
Once skinned up, a driver chamber will be fitted to the throat, a surround to the mouth and then tested before finishing.
