I know this make/model isn't Japanese or has VU meters, but it kicks the 3 brands being discussed into the long grass IMHO.
http://en.audionet.de/machines/watt/
Since you have the L-590AXII, do you usually leave the amp in "Line Straight" or "Loudness" setting? It appears that there are 3 settings with the amp as follows;Size and weight isn't actually too bad compared to some integrated amps.
It sounds detailed but smooth with it. Sweet treble, lush mids. It has that class A flavour but isn't overly syrupy with it. In fact it puts out around 90W at 8 ohms so is probably AB but heavily biased towards class A (and gets suitably warm to prove it). Doesn't need massively efficient speakers because of this. I found it great with all types of music.
I preferred it to the MF Nu Vista 800 (bit too dense for my taste), Unison Research Unico 150 (lacking detail and not great build quality) and power amps from Cyrus, Chord and Bryston connected to ny MFA pre-amp which were all a bit hard sounding and yet no more detailed.
I didn't try it against a vast array of products but heard enough to know it was the amp for me, despite the 70's styling. Of course, YMMV. It may sound very different in your system. Get a demo if you're buying new.
L-509X now but in both cases, I leave it in line straight mode. I don't use the tone controls as my system is pretty well balanced for all types of music. The Loudness button is for low level listening. I assume it squashes the dynamic range somehow. My speakers are very good at low volumes so I don't feel the need there either.Since you have the L-590AXII, do you usually leave the amp in "Line Straight" or "Loudness" setting?
No, the Accuphase sounded great using single ended connections. I believe you'll only notice the difference with long cable runs by virtue of the balanced arrangement's better rejection of exterior interference.Is it a waste to run Luxman and/or Accuphase single ended?
It depends on the source and on the amp. Sources that have been designed around balanced topology are likely to prioritise this and the single-ended outputs may be compromised as a result. The reverse is also true. Same applies to amplifiers. I'd suggest experimenting and using whichever connection method sounds better to your ears.Is it a waste to run Luxman and/or Accuphase single ended?
Thanks for the response. May I ask what speakers do you use with the Luxman?L-509X now but in both cases, I leave it in line straight mode. I don't use the tone controls as my system is pretty well balanced for all types of music. The Loudness button is for low level listening. I assume it squashes the dynamic range somehow. My speakers are very good at low volumes so I don't feel the need there either.
You might as well use XLR by the way as it's a fully balanced design.
Care to enlarge on that?
Just curious.
@maccar Just look at the design both technically and physically, The WATT for example has 2x700va and 1x50va transformers + 200,000uF caps, and a damping factor of around 1000.
Then go see the prices, you'll soon realise you're paying almost double what they sell for in Japan. When buying from the EU (inc UK, for now) you're not getting shafted by the importer/tax.
But the best advice i could offer you is, get a demo.
Cracking DAC you have there Mr ryder. A much underrated device, and much closer to the Chord Dave than some would have you believe.Thanks CK. It's the Luxman L-590AXII and Chord QBD76 DAC.
