I’ve been tweeking my older pre cirkus LP12 and have found the tension of the arm collar bolts that go into the MDF armboard affect the sound quite a bit. It you do then you tighter the sound is also tighter and more detailed but maybe less musical. Done up ok but looser it’s more musical but you loose detail. Anyone ideas of the exact recommendation? Slightly adjustments seem to make a difference too. This is the arm collar bolts.
I remember in that past Linn used to say the armboard is a loosy connection and you shouldn’t do it up tight, but I think that referred to the smaller armboard to subchassis screws. How about the armboard bolts? They do come looser over time as they sink into the MDF too.
Any advice would be much appreciated. How tight should the armboard screws be too? Only just enough to hold it or done up a bit tighter than that?
