Hi buddyA simple test is to gently press straight down onto the top of the motor pulley from above. A properly suspended motor will have the rotating parts shift down by a slight amount and then spring back up to their original position.
Should it not move down at all then it will be riding the bottom bearing sleeve and is likely to be noisier in use than one that is held afloat.
Gonna check your answer on my own table.
Should this be the case do you have a quick fix or would it require pro help?
