Hififriend
Hello.
So I could not stand or bare to change pull out the RCA's when changing the source as there is only one Line Input at my beloved Sudgen headphone amplifier I now use as a preamplifier. So I had the idea to add a second preamplifier to have additional source inputs. (I hope it is clear)
So I connected a Rotel preamplifier RC-990 Bx (no current turned off not even mains in the socket)
which from Tape 1 Out goes into my headphone preamplifier Sudgen HA-4 (only 1 RCA input). From the Sudgen Pre-Out the signal goes in the Main In of a Rotel integrated amplifier RA-980 BX.
So now, instead of 1 source connected to the Sudgen (I like its sound), I have 3 sources: 1. Naim Nat 02 Tuner, 2. Turntable (Naim Stage Line N (phono preamplifier) to Hicap (power supply) in CD and 3. all the inputs from the Rotel RA-980 connected by Tape 1 OUT (Rotel integrated side) to the Aux IN (Rotel preamp).
It works fine but I wonder how much sound quality is suffering for example. Rotel CD player connected to CD input of the Rotel integrated amp RA-980 BX --> signal from Tape 1 OUT --> Rotel Preamplifier Turned completely off (Aux in) --> Sudgen preamplifier PRE OUT--> Main IN of the Rotel RA-980 BX
So instead that the signal goes: from CD --> (CD IN) Rotel RA-980 BX --> speakers, it goes
CD --> (CD in) RA-980 BX (Tape 1 OUT) --> (AUX IN) RC-990 BX (Tape 1 OUT) --> (Line INPUT) Sudgen HA-4 (PRE OUT) --> (MAIN IN) RA-980 BX --> speakers
1. How much sound quality loss ?
2. Why I can't connect a 4rd source in TAPE 1 IN at the Rotel preamplifier RC-990 BX ?
Manual says: Tape 2 out to Tape 1 in = ok (Tape 1 as a recorder)
Tape 1 out to Tape 2 in = NOT OK does not work (Tape 2 as a recorder)
Both Rotel preamp and integrated have no more influence, no more volume control- Integrated record selector has to be on CD (CD input) and Rotel Preamp record selector has to be on AUX (as Tape 1 out (int) goes to Aux in (preamp).
Recording selector shows only TAPE 1 and not Tape 2
But why there is nop sound when I connect a tape deck to Tape 1 in at the Rotel preamplifier RC-990 BX ???
Thanks a lot.
Only discovered yesterday that a signal passes through even when the gear is turned off, quite amazed by this. Looking forward for technical explanation. Signal loop etc
Kind regards.
Thanks a lot.
Kind regards.
