tomek
Hi,
On the "standard" 317 circuit one can (should) use three caps - one across input, one across output and one on the adjust leg. Naim use only two tantal caps, Les is using Panasonic caps.
Does it make sense to use some caps like oscon or silmic around lm317, and if yes, which cap is the most important (output, input or adjust) ?
Cheers, Tomek
Cheers, Tomek
