Hi guys, looking for some advice.
I've just bought one of these tuners from a guy on the Wam but it comes with a power supply plug that obviously plugs into it's matched Leak amplifier.
I am thinking that I can simply fit a standard 13amp three pin plug to the twin wire going into the tuner and cut away the old plug but I'm a bit concerned about which wire in the twin wire is the live and neutral or doesn't this matter?
If so is it just a question of connecting the twin wires to the live and neutral terminals in the plug?
Tony
Tony
