"The following error occurred:
Your content can not be submitted. This is likely because your content is spam-like or contains inappropriate elements. Please change your content or try again later. If you still have problems, please contact an administrator."
Any good tip on how to post pictures? I have a shared iCloud folder I would like to link to...
Hi. I have tried them both. Seems like it's links in general.Maybe a Google-Drive link? Otherwise upload them to Imgur.com and post links here.
[QUOTE="Rug Doc, post: 5095142, member: 28101"So, what are you both going to use as stands for these?
The faulty amp-pack appears to be fixed.
It was the op-amp. I've fitted a replacement and the DC offset is gone.
In due course, I'll make up a dummy test load out of big ol' wirewound resistors. I've got an Prism Dscope computerised audio test set, and I'll do frequency response curves and distortion measurements on the amp packs as a final check, but I don't expect to find anything significant wrong.
Thing still to do include bass-driver-rotating to deal with the slightly sagged one, and sourcing two B300 dust caps from somewhere to replace the missing pair, dealing with ferrofluid and fitting the four replacement B110 dust caps.
Replacement connectors for the amp packs and speaker cables should be with me tomorrow (I think) and our wireman at work is going to look out the tool to release the pins / receptacles from the old ones to swap into the replacement connector bodies.
After that, from an electronics standpoint, I'm done, and it's just paintwork and veneer to do.
Looking promising....
