Musicraft
Trade: Musicraft
"The JL Audio Fathom is of reference quality and a benchmark by which all other subwoofers can be judged." - Robert Harley, The Absolute Sound
Musicraft (Derby) is pleased to announce we have JL Audio's Fathom f212 v2 3600w subwoofer in store -
JL Audio Fathom® v2 -
The challenges associated with designing high-output compact subwoofer systems can be quite daunting. In most cases, designers sacrifice low-frequency extension or output capability in order to keep the design small.
The Fathom® v2 subwoofers sacrifice nothing, thanks to the dynamic advantages of their proprietary JL Audio woofers. These exceptional drivers allow for a true subwoofer passband and very high output, while keeping distortion well below audible thresholds. To extract full benefit from the excursion envelope of its woofer, each Fathom® v2 employs an exceptionally powerful switching amplifier with a large toroidal transformer and a patented circuit designed to enhance control and fidelity.
The compact design and conventional form factor of the Fathoms apply beautifully to most home theater applications, including built-in designs. Front-mounted controls make them a dream to set up and adjust, while JL Audio’s exclusive Digital Automatic Room Optimization circuit makes sure that response is smooth, even in challenging rooms.
Simply put, Fathom® v2 is the compact subwoofer system for those who enjoy demanding program material and won’t settle for compromises.
JL Audio Fathom® f212 v2 Powered Subwoofer with Dual 12-inch Subwoofer Drivers, 3600 watts -
The f212 v2 is the ultimate expression of the Fathom v2 formula. It is ideal for larger spaces thanks to its higher efficiency and higher power output. The combination of dual ultra-long throw W7 12-inch drivers and a very powerful switching amplifier give it jaw-dropping performance capabilities at any listening level.
Because it is built with the same driver and amplifier technology as our flagship Gotham v2, the f212 v2 delivers a tremendous level of sound quality. Low distortion, excellent dynamic capabilities and shockingly deep bass extension will allow you to experience all the excitement of the most demanding cinematic material, while also being able to reproduce all the nuance and texture of your most delicate musical material.
A complete set of signal processing features is easily accessible on the front surface of every Fathom v2. These include a highly flexible low-pass filter, variable phase, switchable polarity, e.l.f. trim and our powerful Digital Automatic Room Optimization (D.A.R.O.) system. A calibrated microphone is included for the D.A.R.O. system. Input connections are made via unbalanced RCA connections or balanced Neutrik® combo XLR/TRS jacks. Also included is an XLR output to connect a second Fathom v2 as a slave unit.
JL Audio Fathom f212 v2 3600w subwoofer is at Musicraft (Derby). Unfathomable sub bass by JL Audio
JL Audio Fathom f212 v2 3600w subwoofer UK RRP £7000
JL Audio's CR-1 Active Subwoofer Crossover is at Musicraft (Derby)
JL Audio CR-1 Active Subwoofer Crossover UK RRP £3249
JL Audio Fathom and Gotham Series drive unit. Unfathomable sub bass by JL Audio
JL Audio Fathom Series active subwoofers. Unfathomable sub bass by JL Audio
JL Audio E Series drive unit. Unfathomable sub bass by JL Audio
JL Audio powered subwoofers will unleash the full dynamics of your audio experience.
Our award-winning line up of powered subwoofer systems begins with proprietary subwoofer drivers and amplifier designs, precisely optimized for their intended physical envelopes and design goals. Because of this, they are not limited by which sub-assemblies are openly available on the world market. Instead, each system is fanatically engineered and precision-built in our Miramar, Florida factory to reflect our passion for spectacular audio and product quality.
Gotham®: Your first look will tell you that you are looking at something special... your first listening session will confirm it beyond a shadow of a doubt.
Fathom®: Compact subwoofer systems for those who enjoy demanding program material and will not settle for compromises.
Fathom IWS®: There is no need to lower your expectations when selecting this remarkable in-wall solution... it's a real Fathom®.
E-Sub: These beautifully crafted powered subwoofers offer a compelling combination of high performance and outstanding value.
Dominion: Our latest solutions deliver a unique answer for applications that require a compact, more affordable subwoofer.
JL Audio CR-1 Active Subwoofer Crossover -
The lucky few who have heard a well-integrated subwoofer in a great audio system know that the subwoofer's effect is profound. While everyone expects the bass extension to improve, most are shocked at the transformation that occurs in the main speakers. They simply open up, delivering improved dynamics, superior imaging and more low-level detail. Many describe it as the greatest speaker upgrade they have ever made.
Over the years, we have calibrated many subwoofer systems in highly critical listening environments, and we have been frustrated by the limitations of active crossovers we have worked with. Tired of struggling with "blunt instruments", we felt that a higher precision tool was needed, so we decided to build it and call it "CR-1". When properly set up, CR-1 creates a listening experience in which the subwoofers and main speakers become one, delivering a cohesive and compelling sonic presentation.
The CR-1 Active Subwoofer Crossover has been designed by audiophiles, for audiophiles. We believe it has no equal, offering a powerful combination of subwoofer/satellite tuning features, and a complete commitment to analogue signal purity.
http://www.theabsolutesound.com/articles/jl-audio-gotham-subwoofer-and-cr-1-crossover/
The Absolute Sound reviews JL Audio's CR-1 Active Subwoofer Crossover
http://www.canadahifi.com/worlds-fi...1-crossover-with-dual-fathom-f112-subwoofers/
Canada Hi-Fi reviews JL Audio's CR-1 Active Subwoofer Crossover
http://www.soundstageultra.com/index.php/equipment-menu/537-jl-audio-cr-1-active-subwoofer-crossover
SoundStage Ultra reviews JL Audio's CR-1 Active Subwoofer Crossover
CR-1 is built around two banks of precision Linkwitz-Riley low-pass and high-pass filters. Multiplying DACs with monolithic ratio matching are employed to adjust the analogue circuit's filter frequencies. This offers superior tracking behaviour and far more precise left/right channel balance, compared to conventional approaches.
Another of CR-1's unique and powerful features is a pair of rotary controls that control the damping of each filter bank. These damping controls dramatically improve the acoustic summing through the crossover region, by compensating for each speaker system's frequency response. At the center of the front panel, a single intuitive, rotary control permits quick adjustment of the relative level between the subwoofer(s) and main speakers.
To minimize distortion and noise, CR-1 employs top-grade component parts in its all-analogue audio circuitry: 1% precision resistors, JFET-input audio-grade op-amps, polypropylene film-and-foil capacitors and metallized-polypropylene film capacitors, to name just a few. We also build CR-1 right here in the U.S.A., to ensure top quality and dependability.
CR-1's input-output design makes it equally adaptable to studio, mastering suite or audiophile two-channel playback environments. To accommodate dual-mode systems, we also include a bypass feature that engages a pass-through from a dedicated "Managed Bass Input" on the rear panel, to the CR-1's subwoofer outputs. This makes it convenient to switch from two-channel to multi-channel mode.
CR-1 is the ultimate tool for subwoofer integration.
***** Musicraft - Clearance + Special Offers List http://www.pinkfishmedia.net/forum/threads/musicraft-derby-clearance-special-offers.98209/ *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Rick @ Musicraft
