Pine Marten
Have been contemplating this for my 30year old Ittok. After reading up and doing some tests, I'm certain the lateral bearings at least are past their best, The nudge test and lateral push with thin paper strip test show some friction with a couple of slightly worse stiction points on the arm in free balance. The arm shows no physical symptoms when playing, Denon DL110 at 1.8g, no groove sticking, jumping or obvious mistracking distortion. The arm has never been subject to undue physical shock, knocks or gorilla arm bolt tightening. I'm going to contact Audio Origami with these symptoms for his take on it. Any fellow Fishies had similar work done, not just on Ittok arms btw. Apart from the obvious physical improvement in arm motion, will new more close tolerance bearings give a noticable improvement in sonic performance? What about the internal rewire? Foam fill or not?
Many thanks.
Many thanks.
