chiily
PFM Special Builder
The subject says it all, but I'm concerned that the voltage may be just too low for my 32.5.
I have two ALW's SR tucked away inside the little pre, dropping the voltage from my DIYCap (pre reg + reg) from 24V to 18.6 (ish). This gives me just over the 5V drop required for the SRs. The voltages appear very stable out of the DIYCap and SRs on my DVM. sadly I don't have a 'scope to check for any analogue signals.
You see, I'm a little disapointed with the sound. I seem to have lost the 'airiness' around the sound, the mid band is not as clear as it once was, quite a bit of background noise has appeared (this could be my aging cartridge). In fact music sounds a little flat.
I have trying shorting out the 27R resistor on the unity gain and final gain stages to not much effect sound wise, and it doesn't matter whether I use Naim stock MC cards or my modified cards (no zener diode, no reg resistors, 56uF SP across the rails), the result is just flat.
I wondered if the reduced voltage could be having any effect on the dynamics of the pre-amp, transistors not working in their proper operating zone (bias), etc.
I could up the voltage out of the DIYCap and the SRs, but it's an awful lot of fiddling and messing about. I just wondered if I would be heading the right direction.
Any thoughts or comments certainly appreciated.
I can provide more information to how the DIYCap is configured if required.
PS. I have removed the relay board too. Signal directly wired output from the final gain stage.
PPS. I'm running a 4 pin black SNAIC directly from the pre to the power and a 5 pin black SNAIC from the DIYCap to the pre to separate the power and signal.
PPPS. The DIYCap 0V is starred from its 5 pin DIN plug. The SR 0V are starred from the pre's star point too.
