iPad case advice.
Rug Doc
I just received an iPad 10 which is great. Also bought an Apple ‘folio’ case (£89) which is going back as it offers no protection at all - might as well use two bits of cardboard from a cereal box… lol
What I’m after is a case with corner protection and a screen protector, but not huge and thick as the form of the iPad is so nice!!
I use a cheap kind of folio thing, it's a bit pish to be honest but it kind of works, a tenner from amazon, I think, much more important though is a screen protector.
I bought one of these below last year. I had another one too, with the camera protection thing, which was on my previous iPad Pro which apple replaced last year FOC cause the up volume button stopped working.
https://www.amazon.co.uk/gp/product/B07TMCXRFV/?tag=pinkfishmedia-21
Can recommend the ESR screen protector too; but the JTech ones are just as good
As for a decent but not silly expensive case; the folio type ones like this are spot on:
https://www.amazon.co.uk/dp/B0B8T3PM4G/?tag=pinkfishmedia-21
Get the screen protectors separately from the case.
I decided to go for maximum protection, and my tablet lives in one of these kiddie cases; well padded, can bounce it about with abandon. Available for iPad too, in different colours
https://www.amazon.co.uk/dp/B095WNPLTC/?tag=pinkfishmedia-21
Thanks all, I got one of these -
ESR Ascend Trifold Case Compatible with iPad 10th Generation (2022, 10.9 Inch), Auto Sleep and Wake, Trifold Stand, Lightweight Hard Back Cover, Frosted Black https://amzn.eu/d/gp0IqDe
and their screen protector too.
Next question - I have an iPad mini first generation.. is it worth fixing the smashed outer screen? It has erratic button pressing going on too… because the screen is cracked I guess. Would changing the screen help, or is it likely to be the touchscreen beneath?
The mini 1st get is worth less than £50 in most circumstances so I wouldn't bother. In fact suspect repair would be more than its worth. They are now 11 years old, which even for Apple who tend to support devices longer than most is old.
