hifinutt
hifinutt
nad 10 or 33NAD ?
Can’t remember model number but I’m sure there’s at least one that runs the BlueOS system/app
Gato amp with npm add on, might be too expensive but used prices around 17-1800 for a 250s NPM
nad 10 or 33NAD ?
I’ve still got it sitting here - unused though as a Luxman 590 is currently in play.I’ve had my eye on the Lyngdorf mainly for the ‘Room Perfect’ processor, what didn’t you like about it?
M10. Many of the NAD integrateds have BluOS capability.NAD ?
It was the NAD C368 I meant as I'm sure the M10 etc might be over budget for the OP, I should have googled it earlier.M10. Many of the NAD integrateds have BluOS capability.
7oaks have ex display £900It was the NAD C658 I meant as I'm sure the M10 etc might be over budget for the OP, I should have googled it earlier.
That’s a DAC/Pre not an integrated.It was the NAD C658 I meant as I'm sure the M10 etc might be over budget for the OP, I should have googled it earlier.
Sorry it was a typo, I meant C368That’s a DAC/Pre not an integrated.
https://nadelectronics.com/product/c-658-bluos-streaming-dac/
Linn have had this perfected for a very long time, they have the software nailed, with a wealth of native support for the major streaming services and an intuitive app that pulls them all together along with your own library. The hardware is also really well sorted and sounds great. It’s easily one of the most established high end platforms out there.
For less money, I like the Bluesound stuff, for the same reason as Linn, solid software and native support of streaming services, the hardware is great too, I’d look at a Powernode, it’s a neat product... I’ve still no idea why people would use Roon with Linn or Bluesound, because their own apps just work so well.
The current Naim Uniti products are excellent too, again, very well polished.
I’ve used them for twelve years without any problems, as have many others but there you go... I used to use third party apps for control such as PlugPlayer because they worked better but I’ve used Linn’s own apps for a few years now, they’ve come a long way. Kazoo recognises the DS and my libraries in an instant. Roon isn’t worth the outlay for me, if I want to listen to something, I can find it and have it playing in seconds via the Linn app. I can’t fault it, hence why I mentioned it along with Bluesound and Naim (who have also come a long way).That's certainly not my experience of the Linn app/hardware. In common with many others, I found the app clunky and prone to connection/recognition problems. It was, by far, the worst I've experienced. Before anyone comments about network problems, I can assure all that this is not the case. In the same system, with same network and config many other apps/hardware worked/work first time, every time.
The reason why so many Linn users use Roon is to address connectivity problems, along with the desire for a far better interface than the Linn app.
Auralic and Naim have good apps, with Bluesound being very stable and easy to navigate. Roon is definitely a class above all, but does cost extra.
This is very sound advice.Find a used Auralic Polaris.
Yamaha 803D any day of the week. Proper vfm.
A very good analogue amp with a digital section. I use mine in pure audio mode with the sub attached to the speaker outputs.I don't usually get caught up in the science of components as I am a listener, not a measurer. However, I have looked at this myself as it does seem to have an enviable array of features for the money. What I can't work out from the reviews is whether it's actually an AV component masquerading as an amp/streamer or the other way around.
I'd be using it exclusively as a 2ch unit - how good is it in that regard compared to other suggestions made like the Linn MDSM (always liked Linn's sound but put off by their overpricing) and Naim Uniti Atom?
