Hi
After many years I managed again to acquire a pair of pro monitors 3 (reference?) which have needed very serious refurbishment, which I have now almost completed. I am now left with the problem of tweeters.
The speakers at times in their lives have been modified on many occasions with different drivers and xovers. When I got them they even had two different makes and types of tweeters which I have at least managed to change to a pair of the same type from an earlier incarnation of the speakers but they really need replacement as they are definitely not the correct fitments .
Originally I believe they may have had T27s or like a previous pair that I had in the 70s HF1300s. Now rather than go looking for a pair of thirty year old tweeters, I intend to replace/upgrade but trying to retain the overall nature of the beasts.
From recommendations I am considering the Morel CAT308 as a candidate, I believe the MDT30 was considered a good replacement for the HF1300, and the CAT308 is its successor. I contacted Wimslow but he seems enamored with the Morel Cat298 saying its an excellent replacement for the T27 needing no mods. But does not seem to want to say too much about the 308.
Here is the problem I have never heard either the 298 or 308, and I was wondering if anyone has any opinions on which would be better, as I said I am leaning more towards the 308 as they are supposed to be a smoother better driver. I am aware that I would have to tweak the xover for sensitivity with the 308 . And as I said I did some years ago have what was a later pair of pro monitors with the HF1300s which I found very satisfying.
Incidentally does anyone know what were the differences between the reference pro monitor and pro monitor mk3s if any. These present ones though having the formica rear panel differ from the other pair I had in several ways and trying to get info on the earlier versions is rather difficult, even the sites dedicated to the IMFs have a lack of info on the earlier versions.
I have found a picture on the net of a identical pair to mine (a dealer) which he identified as a TDL IMF Reference pro monitor (yup I know) I am not sure if it would be ok to post the link to the pic but I do have it If anyone is interested.
Any comments much appreciated.
