I made this a public question as I think this is important question for many. Do not know if every country has the system we do in my country for the electrical assemblies but at least Germany and Scandinavia is uniformed in same manner.
We do have fuses in our house/flat electrical centre or table. No fuses on plugs like in U.K.
Now I am having newer flat with electronic thermal brakers which tend to be quite fast and sensitive.
Normal 230V sockets are fused by 11A fuses and the grounded ones are fused by 16A fuses.
TRANSFORMERS CARRIED IN NOW!
My DIY jobs apply huge transformers like a HiCap one or bigger. Also I have made trials with huge switching PSUs.
Switching ones are not problematic as they have slow start or relay start systems which can handle starting fuse friendly way.
But the transformers! I cut our brakers every time. Propably I have assumed few transformers to be broken even they are not for this reason.
I have tried to keep a breaker on by hand but then there blows the local fuse.
Now, one fault have obviously been that I have used only 5A fuse near the transformer (a HiCap uses 5A, slow, fuse BTW).
Should I try a bigger one, 10A, 13A glass fuse in the transformer box?? Then I will still have the house breaker problem..?
What would be the best solution to make these transformers to start at least once. Then they can stay on.. ??
Slow start modules?? Just resistors before them??
Or just go to smaller R-cores and enjoy the quality, not the power?
HELP ME PLEASE!! (Cos' I desire more tune!)
Oz
Oz
