NewtonSheep
it seems the speaker has two voice coils on the same former.
Use an amp, push current through the voice-coil immersed in the speakers magnetic field - the coil moves, and with it the speaker cone = sound out.
But the unconnected second voice coil attached to this cone is also being moved through the driver's magnetic field, so it works like a generator - a voltage will appear across its terminals.
Connect those terminals together with a wire link, or a resistor, and the amplifier has to do more work - because the second voice coil is now acting like a brake on the speaker cone's movement. Changing the resistor value changes the added braking. It will be none when open (unconnected), least effect for a high value resistor (little current flow) to most when you use a very low value resistor, a wire link - or a powered amplifier with no applied signal like the article! And essentially that's why the article noted such a config gave 'lean' /'taught' bass.
Any help?
Yes, very helpful. I understood that Thanks.
