I won a 2.3m pair of these potentially fabulous cables on eBay, but the previous owner had them reterminated with spade connectors. Turns it he did this himself, and it showed.
I have snipped off his work, but I noted that at the single pair end there are two fat cables (white and black), and two thin cables (white and black). The previous owner had soldered both thin cables and the fat black to one spade; and the fat white white to the other spade.
I want to reterminate these cables with 4mm plugs, initially screw on types to test the cables out, then if I like them I'll have the job done professionally. My question is what do I do with the thin cables?
Also can anyone recommend a quality silver solder termination company?
Rich
Rich
