I have ,for decades, joined two round section rubber belts (about 1.5mm diameter) to make one long one for my modified Connoisseur BD1. The joins usually lasted for several years, 6 days out of 7 usage.
My method was to cut and square up the loose ends with a scalpel (used a head magnifier to check squareness).
Then put one (1) drop of superglue on a metal plate and dipped one end of one belt into the glue (shallow dip). Then I held the join as it dried, turning it every few seconds at the beginning to ensure that the two ends were evenly joined on all sides.
Some years ago I discovered that a superglue called ‘Zapagap’ is stronger than ordinary superglue, and fills in the gaps in the rubber. This product is obtainable from only a few sources; I got mine from Axminster Power Tools (they are online).
Recently, following a tip from Dr. van den Hul, I constructed home made long belts out of polyester thread. (see the Sugden Connoisseur thread on pfm for further details).
This new belt has no disadvantages that I have discovered, and can be constructed for about 10p per long belt. It took me less than 5 minutes to make it. I think that it will last a long time and certainly gives an audible improvement on wow and flutter.
I would say it is worth a try. You might save a lot of time and bother, and get better performance if you use polyester (or silk as Dr. vdH does) and make a substitute belt for your TT.
