onbellyman
Member
Hello everyone.
Im new to this forum and not sure if this query is in the right place but mods will no doubt put me on the right track so here goes .
I have a Sony TA-F246E Amplifier that I bought new in 1996. It has Sony ST-5261 Tuner, Sony TC-K561S Tape Cassette deck, Technics SL-PD887 CD Changer and Garrard AP76 turntable connected to it. Not High-End stuff but it does what I want.
The amp has been working fine until recently when it has developed a peculiar noise. The noise is heard just after the Power button is pressed, when the light turns from red to green. The noise sounds like a constant low volume clicking (kind of like a Geiger counter?) accompanied by a slight hum that rises and falls in a regular pattern about once a second. This noise continues if I then power up any of the other components that are connected to the amp. The amp seems to put the chosen audio signal through the speakers as usual but whenever there is a pause in the music or radio, I can hear this background noise.
Any ideas as to what is wrong here?
Is it worth getting someone to look at it or would it be more cost effective to just pick up another second-hand amplifier?
Cheers
Ian
Cheers
Ian
