canonman
Gitzo G-1128 Mk2 Mountaineer Carbon Fibre (Compact) Tripod Legs (Rapid Column) - Supports 9.90 lb (4.49 kg)
No tripod head.
Excellent condition - very light use. All locks are tight and positive. Cosmetically excellent.
Maximum Height 54.7 inch; (138.9 cm)
Maximum Height w/o Column Extended 46.1 inch; (117.1 cm)
Minimum Height 12.2 inch; (31.0 cm)
Folded Length 18.5 inch; (47.0 cm)
Load Capacity 9.90 lb (4.49 kg)
Leg Sections 4
Leg Lock Type Twist
Independent Leg Spread Yes
Centre Column Sections 1
Centre Column Type Sliding
Head Mount Thread Size 1/4 inch-20 & 3/8 inch-16 (reversible stud)
Weight 2.60 lb (1.18 kg)
£150 collected from Windsor or shipped by courier for £8 extra
No tripod head.
Leg Sections 4
Leg Lock Type Twist
