neilmack
In superb condition, with swivelling rubber foot. Professional quality and robust build. Negligible signs of use.
From the manufacturer's website -
The Gitzo GM4532 is a 3-section, lightweight carbon fiber monopod. It is the fastest to operate model with the strongest structure in the range. This Series 4 monopod leverages larger tube size (top leg diameter 37.0mm) and stiff Carbon eXact tubes to deliver rock-solid stability for professional DSLRs, long lenses, and video cameras. However, it is extremely lightweight and slim enough to grip comfortably. Gitzo’s G-Lock Ultra system makes the tubing even stronger by rigidly connecting the leg sections, protecting joints from moisture and dirt.
The GM4532 reaches up to 163 cm, securely supporting an impressive 30 kg-worth of equipment. It weighs just 670 grams, and folds down to 66 cm.
£149
£149
