Gitzo Gilux Reporter Series 2 Tripod
Main legs 28mm (1 1/8 inch) diameter
3 section leg
No column supplied (28mm diameter will be needed, the collar and sleeve are present and correct)
(The column was used in another set-up and now unfortunately not available)
Max height 42 inches to top of tripod plate
Minimum collapsed size 19 inches
Tripod has been dismantled, cleaned and greased, and reassembled, all rings and rubbers in good order
Paint not in best condition, one leg has lots of paint chips from one bad travel in the car boot – see pictures
For all the wear and tear this is a very useable tripod that you need not feel precious to use
Bottom sections marked form use, but after the service all is clean, greased and locks firmly
£40
(Spanner not included)
Various heads are available, including a couple of Leitz heads, please ask for details
3 section leg
£40
