sq225917
Bit of this, bit of that
So ive built a BPBP pre amp with a remote control stepped attenuator and ill only be running two sources so only one switch needed. The way the connections run i can bodge in any switch type, i could make one from a trailing Trs plug and two sockets if i wanted.
Question is what cool switch gear you seen? All examples kindly received.
I fancy making it look a bit like an analogue patch bay synth, led display, one rotary and a two option trs plug on short lead. I can do anything with the chassis so fancy having some fun.
