Focal Utopia .. which tube amp with remote control and balanced output ?
maro73
Hello folks
It’s been ages since I’ve been active
Time dedicated to work and enjoying my system
I have a Focal Utopia for some years now , they do sound good with the Violectric V281 (which is a stunning pre amp on its own) , linked to Chord DAVE via XLR
I just wanted to try a tube headphone amp .. seems that Feliks audio is good ..
Any ideas for a tube headphone amp ?
Cheers
If you head over to Head-Fi there are a number of threads/posts on this very subject. Never used tubes with my Utopias but got some good sounds with HeadAmps FWIW.
I run a Cayin 300b, I’ve been lucky and had a number of different amps (Mcintosh etc) and this is in a totally different league. I can wholeheartedly recommend. You would need some flexibility on your budget though.
I looked at valved can amps some years ago and found them either limited in versatility (only one can outlet or1/2 inputs only). Eventually chose a class A Myryad with all the bells and a good sound, though at the price I paid it was a steal regardless, so findings were well ahead of expectations (HD650 + Elears).
The ones I narrowed down were a Jap. one (HA 501?????) and an eastern European one, both in the 450 to 600 pound bracket then.
Hello Guys
To be honest , I’m really happy with the Violectric V281 (Which is by the way a superb pre amp on its own) .. but I really think that tube head amp is the way to go
I read Headfi .. so much information , and not convincing
Right now , limitations are the Remote and XLR input (my DAC is far from office)
Next visit to UK : I’ll search for the Ear HP 4 , the Cayin 300b
The looks of the Mcintosh appeals a lot to me ..
The search is on
I’ll take any recommendation
Cheers
Just posted in the specialised forum
Seems that PATHOS is the way to go : INPOL ear headphone amp
Loks good
I’m currently using a Pathos Aurium with my Utopias, way under the budget being spoken to here obviously, but I think it’s more suited to my HD800’s than the Utopias. Pondering whether a Focal Arche would be an upgrade, I’ve seen those for £1500, or if a more expensive tube amp would suit.
Hello
I've listened to the Viva .. fantastic but budget is over the top
ARCHE : too expensive for the price : just a marketing stuff
For the Utopia : I 'm using : Chord Dave alone , Violectric v281 with the DAVE in XLR , Exams DAC DP1 , and the new arrival : Pathos Input Ear ...
Difficult to say : but the Pathos rivals the Dave + V281
Will post soon
Cheers
Pathos Inpol at £4.5k is way above my budget :confused:
As for the Dave…
I’m looking to spend around 2-2.5k at most. Any thoughts?
Honestly , I think that the Utopies need tubes
Just check for Icon Audio : Mr Shaw is great talking to ..
I'll definitely try
I didn't buy them because I needed remote and XLR
I don't think that Arche will better the Aurium
Hope that helps
Cheers
Ah , just to say that the Pathos Input ear without Dac is not the way to go IMHO
Unfortunately rare to find second hand
Cheers
I'll definitely try
Hope that helps
Cheers
thanks very much, will take a look
