Hi James,Mogami 2972 is pretty much the standard speaker cable for pros, and it works a treat with my CB NAIT2. Super-flexible too.
You should have called it 'Matchbox 20', like I suggested, Jez....Indeed... bad design as it's also known.
I "designed" (too simple to be termed designed really!) an add on box to remedy the problem with all these types of amps but had only one solitary enquiry! (bizarrely it resulted in the single sale I made for this).
I presume owners of these amps don't believe they are badly designed and assume there is a damn good reason for them being this way...(wrong!). Hence no interest.
The actual minimum length will depend on the speaker capacitance, something never published. ESLs look like pure capacitance above 20 kHz, but even conventional speakers can have the crossover bass filter inductor go self resonant at low ultrasonic frequenciesHi James,
Your 2972 is a good match for Naim cable on loop inductance (75% of A4/A5 value), however, parallel capacitance is higher by a factor of 3.94. As such, Excel returns 5m minimum and 5.08m maximum lengths, with the minimum matching the recommended 3.5m NAC A5 on loop inductance (3.5µH total), and the maximum length matching 20m of Naim cable on parallel capacitance (320pF total). Series resistance is virtually identical with the Mogami being 0.98 of Naim's (0.0088 vs. 0.009Ω/m)
Obviously, the ideal length of 2972 is 5.04m.
I do love all these recommendations for speaker cable.
Names like Mogami 2972 are intriguing.
I wonder what ‘2972’ signifies ?
I was just reading about these yesterday, and noticed a pattern, Peter.I think 2972 is just a catalogue number, Mogami make a vast range of cables for pro music industry use and I don't think there's any hidden meaning in the number!
The thinner cables are adding enough resistance to reduce the speaker output at the lowest impedance frequencies, usually either side of the upper port resonance. This might well be enough to sound thinner, but also faster.Tried several copper cables with the Nait. From thin 0.65mm^2 47 labs, to noname single core about twice thicker, to average gauge multi strand copper, to thick old AQ. They sound non spectacular in the good sense, with a simple thicker = weightier sound equation. Others were too tonally skewed.
The first (breakable) and last are not flexible.
