philiphifi
hi - i just been on the diyaudio and read reviews on the FW F5. Is it true that the sound is that good? It is easy to build and doesn't cost that much
I have the F4. It has no feedback and no voltage gain, only current gain. It needs a pre with sufficient output to drive it but I find it sounds fabulous with my Tubes4hifi valve pre. Again, efficient loudspeakers are required. My Ref 3a speakers are >90dB.
I've read that Mr Pass' favourite designs however are single ended. Must try one sometime. The great thing is that once you have the case and psu you can try different amplifiers. When I get the time I will try converting my F4 to a 'Sissy Sit' with VFETs.
are they different to the commercial pass lab? these cost a fortune
thanks gents. What about the components and transformers? i built 2 preamps with different resistors and caps and they sound very different.
The person that built mine said it doesn't really matter as long as the components are good quality. The innate sound of the amps has more to do with the circuit design than the components.
I have a pair of DIY Aleph 60 monoblocks - single-ended Class A. I heard a pair of SIT amps last year and they were stunning but cost a fortune.
Hi Philip,
The F6 especially is very easy to build and gives excellent results. You can buy the kit of PCB and transformers from the DIYAudio shop and also some of the matched FETs as well. The rest of the components you can get from RS, Farnell, CPC, Rapid, and Cricklewood in the UK. As with all Pass circuits/kits it gives about 25 Watts of very clean audio.
One thing I would initially advise against is mounting the transformers on the PCB as they are susceptible to electromagnetic hum pickup from the power transformers. I attached mine using longish leads, about 10"/30cm long, and moved them around for minimum hum then fixed them in place using thin Ali strips, Tyraps and sticky pads. Residual hum and noise down in the -90dB WRT 775mV.
John
Thank you very much. On various forums, the F5 seems more popular than the F6. Is there a reason for that or is it just that it is new?Hi Philip,
John
