A longer cable length from router to streamer (as many meters as one can afford) is preferred by some as well
in fairness, since we are all different, it's worth remembering that some people are more sensitive than others.
Did this at The Wam after some discussion. It took a few months to settle down but IIRC the theory was working (ish) quite well for the believers. I doubt the unbelievers were chuffed since they had nothing left to say.Or have a separate section for cables, cable lifters, mystical grounding devices and magic carpets (think rugs) as is done on AOS.
Then those who believe in such can party on.
On another forum there is a (?) consensus that the switch makes a difference. I swapped my netgear for an Ebay Cisco 2960 - and was staggered by the difference.
Yes switches are something that I will be looking at at a later stage. I was surprised and pleased enough by how much different the MeiCord Opal Ethernet cable made.
I assume any comments to this will end up being deleted. Can we please just delete the whole thread instead of letting some claims stand unchallenged?
It's my objective opinion.
In cable threads nobody is allowed to challenge objective opinions therefore what I said is accurate and wholly correct.
Yes, let’s just delete everything you disagree with! Think of the time it would save you posting much the same thing over and over again. Come to think of it I would waste less time as well .I assume any comments to this will end up being deleted. Can we please just delete the whole thread instead of letting some claims stand unchallenged?
Why don’t you report it, LOL.
Mr. Dog, I put an alternative explanation to you. It is because you are a tight git.The less to fixate over the better IMO which is why I have monoblock amps with 150mm of speaker cable hard wired to the amps.
I was taking the mick a bit. I have monoblocs very close to the speaker terminalsOnly as tight as the engineers at Abbey Road Studio
See my post 125.
Though I believe that many believe they have systems more revealing than those used in the studio and or better hearing.
