Well I got my hands on a few cameras today - the Sony A350, Nikon D60, Pentax K-m/K2000 and the Canon EOS450D.
I definitely agree on the advice on trying different cameras out - the Sony just didn't either look or feel right to me.
My two favourites on handling grounds alone were the Pentax and the Canon. My favourite was probably the Canon, but then it is a fair bit pricier that the Pentax. I have some more questions which I'd appreciate some advice.
Firstly on the Pentax - there seems some conflicting advice out there as to whether the K-m is a replacement or a level down from the K200D. There is an article in What Camera, which seems to try to position it as a replacement, given that they have stopped selling these in Japan. DPReview.com (a site I know is not highly rated here) has the K-m more as a cut down K200D. If so, the K200D has come down so much in price, that it's nearly the same cost as a K-m and may be a bargain. So if I went for a Pentax -which should I go for. Does the K-m improve in areas on the K200D?
Looking at dpreview.com - they say this of the K-m
"For all the reasons above the K2000 is a difficult camera to rate, combining as it does an excellent feature set with a fairly fundamental flaw (the inability to easily check or select the focus point being used) that we consider to be serious enough to be a deciding issue. The lack of focus point indication is also, crucially, something that we feel the target market (the first time buyer) would benefit from (small viewfinders and slow zooms don't make it easy to spot when the camera hasn't focused where you want it to). The target user is also much more likely to shoot JPEG than to process raw files in ACR, and the difference between the K2000's raw and JPEG output is so great that we've been forced to split the image quality score in the table below."
Can anyone explain whether this is as critical as they make out.
Secondly on the Canon - this was probably my preferred option in terms of handling. Again, I hear very conflicting reports on the quality of the kit lens. Is it OK to live with as given this is right at the top of the budget, I won't have any money to spend on accessories for a while.
I'm also interested in the price of lenses going forward - given that image stablisation is in the camera for Pentax, and also with the backward compatibility of older lenses - does this significantly reduce the cost for new lenses, or does the greater choice from other lens makers compensate for this with the Canon?
Any help greatly appreciated.
Cheers
David
