I said in my first post, #10 on this thread, that originally I was going to make a T cable using the Mogami cable for my Ittock but I ended up buying an Ekos SE which came with a Linn supplied Mogami T-cable so I didn't need to in the end.
I posted the pictures in #14 to help identify how the T Cable was constructed from pictures I had downloaded from the various Linny sites. Unfortunately I cannot now find where I got them from especially the Excel sheet showing a connection truth table which I am now convinced is not very truthful at all.
Having muddied the waters by posting what appears to be an erroneous truth table I too would like to get to the bottom of exactly how the screens are connected.
Of course I have my own LP12 with Mogami T cable to measure but I have been reluctant to touch the deck as it was upgraded with Kore, Karousel, Radikal 2, Ekos SE and Kandid about 6 months ago by you know who of Leicester and I don't want to upset the cable dressing etc.
However, to answer the question of are the screens connected to the centre earth pin of the din plug and each other I realised this could be measured from the two phono plugs and the earth lead by simply unplugging from the pre amp.
Here are some pics of the cable which confirms it is definitely constructed from Mogami 2549 and it bears a sticker with what looks like Linn reference numbers for its build spec which I know was manufactured towards the end of 2020.
To take the measurements I just unplugged the two phono plugs and the earth lead from the Superline phono stage and using a Fluke 87 got the following readings.
Red Phono inner pin to phono body :- 6.8 Ohms (Right coil resistance)
White Phono inner pin to phono body :- 6.8 Ohms (Left coil resistance)
Thin earth lead to Ekos body and deck plate:- 0.3 Ohms - continuity as expected.
Thin earth lead to Red phono body :- >999 MOhms infinity.
Thin earth lead to White phono body :- >999 MOhms infinity.
Red phono body to White phono body :- >999 MOhms infinity.
I think this proves conclusively that the thin earth lead connects only to the arm earth via the central Din pin and then on to the chassis and is not connected to the two screens.
We can see from the photos in post #14 that the screens are connected at each phono body to the blue signal return but the two screens are most definitely not connected to each other or the thin earth lead.
This now makes perfect sense and is consistent with how
@jagdesign made his cable.
I tried to trace where the Excel spread sheet originated but drew a blank.
Just after I posted this I noticed the label reads Rev 13 - could there be 12 other variants ????
