I have a very old 6 element FM aerial on the roof. The signal has deterioated so much that its next to useless. The local aerial guys are quoting silly money for a replacement or a rewire so I played about with DIY Dipoles.
Basic Design
Strip back the aerial cable about 15 cm
wrap the earth/shield round one munsen and screw it onto one of the pipes
Wrap the solid centre core round the other munsen and screw it to the other pipe
Fit the aerial plug to the cable jobe done.
Mount it horiziontal as high as you can get it.
Comparison from signal strengh meter on tuner
Old 6 element aerial of roof - 8d
omni directional circular bought dipole aerial in loft - 34db
DIY dipole on chair in bed room - 29db
DIY dipole in loft with cheap cable and a couple of connectors to fix it to the tuner - 39db
DIY dipole in loft with Belden 1694A as a down lead and a new connector - 40db
Belden 1694A
Looking for the best possible downlead I though Belden 1694A was the eay to go. Its an ultra high quality RG6 video cable designed for the most demanding of video uses.
Foolishly decided to rip out the 3 1694A out of a lenghly component cable bundle. I can only say it took nearly 2 hours just to get the cable out - I cant remember what the product code is for the bundle but its construction was serious. The 1694A's exemplary construction pales in comparison. I can honestly say I have never worked with such un forgiving cables before. PS they dont bend easily either
But it delivered an extra 1db on a 6m down cable.
Basic Design
- 15mm copper pipe cut into 70cm lenghts give take
- A 15mm plastic push fit equal tee.
- Two brass Munsen
- CT100 75 Ohm aerial cable or similar copper core copper shield coaxial cable
- 1 aerial plug to fit tuner aerial socket (check is the tuner a male or female connector)
Belden 1694A
