Whilst there is merit in the behaviour of electrons/signals/cables etc., I don't beleive it makes that much difference to a system. Admittedly, I only covered electronics and digital electronics at a fairly 'basic' level at University, however, my ears are either very kind to me or the influence of cables upon sound quality is limited. I prefer to go with the second option! I make the assumption that the cables used are actually fit for the purpose.
I borrowed several sets of cables from my local dealer to 'audition' for a few weeks at a time. I really couldn't tell one from the other, even though I tried to hear several hundred £'s worth of difference between the cheapo set (QED) and the ridiculous set (Nordost (Ithink)). So I bought the QED and a few dozen CD's/LP's. If there was an improvement is sound quality, I simply didn't hear it from my B&W800's. Same goes for directionality too. If it's there, I don't hear it so consquently I don't worry about it but use my dosh to buy more software!
I'm not dissing those that can (or want to) hear differences or improvements. If it floats yer boat then good on yer!
