It is an interesting area of turntable design as there are conflicting requirements. It is clear the main bearing and arm-mount must be fixed relative to one another as the modulation the stylus is reading is so small. That is however a different thing to being rigidly coupled, though that seems to be the cheapest and easiest way to achieve something at least theoretically close to that ideal. The risk as I see it is trapping energy in that loop that will find its way back to the cartridge sometime later, e.g. sink energy back into the armbase and plinth and chances are it is going to come back at some point. It is an engineering question that has never been satisfactorily answered to my mind. Mass is often used, and I’m far from convinced that is the best approach, at least not without clear logic behind it, though it certainly seems to dominate current high-end thinking. Also many things are claimed to be “rigid” which clearly aren’t, especially at audio frequencies.
I find it fascinating, but I’m not sure I’m convinced by any argument. I can find turntables and arms I like in most design schools so I suspect implementation is really the key.
PS I assume it is a Lenco that is being considered here? In which case mass does seem to be the dominant theory by far. I can see a strong argument for mounting the motor on the bottom part of a split plinth though. JC Verdier did this with TD-124s and I think Martin Bastin did the same with Garrards too, i.e. remove the mechanical link between the motor and metal top-plate even more so than the existing suspension. Makes sense.
