Can anyone suggest what the problem could be on my newly constructed Air Guitariste pre ?
Problem - low level crackling sound on one channel. Independant of volume i.e it doesn't get louder unless the volume is wound right up and even then it doesn't get that much louder. Problem is definitely in one side of the pre amp.
Used with a single ALWSR, powered from a Naim 140 power amp running at 21.2volts (at the moment) to both channels. Not sure the noise was there before I added the SR and I'm not going to disconnect anything just yet - enjoying it too much ! Running into passive SBLs.
I've checked all joints and they look ok, although used lead free solder and dry joints are a little more difficult to recognise. Could it be a faulty cap or really a dodgy connection ?
Using Simics instead of Evox SMRs at the moment. (Anyone got any spare ??)
Any help/comments would be appreciated.
