Julf
Facts are our friends
Archimago has written up a pretty good Computer Audio Basics blog entry.
Maybe because of how the clocks are distributed? As far as I recall, airplay is just another network streaming protocol running over 2.4G wifi with sender-controlled clock to achieve ie. multi-room sync (unlike other streaming protocols). This has high potential for time jitter, especially on a wireless link, if coupled directly to a DAC (which I think these devices are).Curious as to why he brands Apple Air Play as "non-audiophile"? It isn't high-res, but other than that I don't see why it should be inferior to a SB Touch, Pi or whatever. In fact I briefly tried a SB Touch and LMS against my normal iTunes and Airplay and ditched it within a week or two as I couldn't hear and advantage and the interface was hideous compared to using an iPhone as a remote!
I have an Airport Express optically connected to a Deltec PDM3 DAC, and whilst it doesn't sound as good as playing a CD on the Rega Apollo-R I use as a transport it is presentable enough. These days I mainly use it as a method of accessing iPlayer Radio as it means I can grab any R3 program whenever I want rather than when it is broadcast (just streaming to the AE/DAC from the iPhone or iPad, no computer needed).
It's only a guess, but if Ethernet cables give out any sort of RFI, then the shielding would help stop this RFI noise being picked up by analogue line level cables running alongside.
Possibly - but the RF noise from twisted pairs is pretty minimal. Do you have long runs of (unbalanced) line level audio running next to the ethernet?
Don't forget the shielding only does its job properly if the whole system is shielded (i.e. sockets, plugs etc as well as the cable)
I'm amazed how many people use shielded cable without considering this.
