Rockmeister
I have about 350 to do. Some are near mint, some date back 60 years and are 'well used'.
I'm not a conservationist as such. If they need glue i apply glue. My past method has been warm water and a little soap. Gentle ordinary soap, then a damp cloth rinse and hang on the washing line to dry.
It works well. I then put then inside plastic covers and that's it.
However, my pal has just given up records and donated me his 50 or 60 as well, and I want to care for them as best as possible, so what method is suggested for the covers please, and if it saves time, I'd be glad. You know, that miracle spray that makes every shine like new whilst protecting them for another 100 years
Thanks.
Thanks.
