Choosing reservoir caps.....
When I posted the link in #1.....I took a chance, and ordered the remaining 4 caps that were then in stock, and also back ordered another 4 that will be sent out in the next few weeks!
At £12 per piece, the price was good when compared to a Mouser UK and Farnell UK price of around £28 each
....a good buy I think! :)
Certainly good caps but you'll need to get some new clamps for them because they are a lot narrower than the originals.
I'd have gone with these as the closest equivalent to the originals and are a drop in replacement.
It's a bit of a bodge to do that really and you will need a lot of insulating tape which will go all nasty and sticky over time.
I certainly wouldn't be at all happy to receive used equipment in that sort of condition.
Yes - in engineering it'd be called a bushing.
It would be called 'bodgery' and get rejected back for rework. Use the correct size, search function is up at the top right
I'd be more inclined to de-solder the screw terminations and use soldered in caps, more choice. Samwha HC or Kendeils likely to be best option. Make sure that Kendeils have embossed gold writing (not printed yellow)
