I want to change out my P9's wood surround for a color change but also it seems like one of the plastic inserts is coming apart (its a 2 peice, I think). Is there any instruction on it.
It seems straight forward but you never know. Has anybody done this before? My main concern is the screws into the MDF plinth. I know that the frame on this table was changed once before. As well as I took out one screw in and out about 3 times in order to fix/reset the plastic frame insert. Is the plinth's MDF strong enough for the screws to go in and out repeatedly like this?
Thanks guys for any input,
Bobby
Bobby
