That is correct Jim. I am not disputing the math. However, in practice with a valve/tube phono stage, when you transformer couple an MC cartridge via step-up transformer the AC load presented to the cartridge makes no difference to the sound whether it is 470ohm (1:10 ratio) or 117ohm (1:20 ratio) when presented by the 47K phono stage input impedance. It is the gain that is important to get right, not cartridge loading with a valve/tube phono stage. If people want to fit a resistor to the primary of the SUT then that is up to them but it seems a huge shame to fit a couple of resisters across the beautifully wound cartridge coils, not to mention what that will do to the sound. OK you don't have a choice when using a solid state phono stage, unless it is set for MM and you use an external SUT.Not sure that is clear/accurate.
A *voltage* step up of 1:10 means an *impedance" step up of 1:100 as presented to the amp. Reverse that for what gets presented to the cart.
Follows from Energy Conservation. In practice you need to know both the cart's output impedance and the amp's input impedance to work out the details. But if we assume an amp with, say, a 47k input impedance and sensitivity of 5mV then using a a 1:10 perfect step-up transformer will present a loading of 470 Ohms with a sensitivity of 0.5mV to the cart.
Because Jim, that is what people do to get exactly the "correct" load impedance to the cartridge. They solder a resistor of the desired load impedance to the SUT input transformer primary windings. Changing the 47K RIAA input resister which is connected to the secondary of the SUT, especially increasing the resistance to give a recommended reflected load has a detrimental effect to performance so should be kept at 47K or 50K ohms.Not sure why you assumed any need to add esistor to the primary. Is that based on worrying about the change in any load capacitance? (This also, of course, gets transfomed by the transformer.)
Curiously, when I did some comparisons of the situation for MCs vs MMs taking transformers into account, the carts came out to be more similar that people might expect!
https://www.audiomisc.co.uk/HFN/MagneticMyths/MMvsMC.html
Which is based around the 103R 14 ohm model. Same compliance and tip as standard 103.
The DL-A110 is based on the 103 and is 40 Ohms. Some sites show 14 Ohms by mistake.Is it really? Have you any confirmation on this? I never cared much for the 103R, so this note is quite intriguing.
The manual shows spec.
multiple image
Rothwell have a lot of info on Denon carts and SUTs, they recommend using their MCL with 1:20, you lose a bit of output 4.5mV but the SNR is better.Presenting 40 Ohms from an amp with 47k input impedance implies using a SUT with a turns ratio of just under 35. So means the voltage will be stepped up by that amount. Assuming I just played the right tune on the buttons of my calc here. Lower ratio may make sense if needed to tweak the response curve but may reduce the available signal power. Choice also would depend on the details of the amp's noise generator values if you want optimum SNR rather than best upconversion of signal power.
step-up transformers for Denon cartridges
www.rothwellaudioproducts.co.uk
Absolutely Jim. That is just one of the reasons why I don't recommend doing it. Second point: Not without a lot of digging...That's weird as it wastes signal power, etc! Can you point me at some detailed examples that include measured details of performance, etc?
