What is this query about...the internal wiring within the arm or the external cable? As an external cable, Cardas Golden Cross is nice (well, I use it so I would think that). Smooth, slightly warm and grain free..
Internally, the issue is less the sound of a few inches of wire, than any obstruction to the bearing. Frankly, much rewiring is a menace, because the wire is either too thick or too stiff. The last thing you want to do is obstruct the bearing. That's one reason Kondo internal wiring works well, it is very thin and not at all 'springy'. Personally, I would avoid rewiring unless genuinely necessary.
As for Vdh cabling....the main onslaught against it comes from dealers, because 'upgrades' on the cable are often more profitable than the actual profit on the arm. What do you expect them to say? Which isn't to say you might not prefer another cable, but not because Vdh is a bad cable. It is fine.
