I would love to get the Festool track saw, but at $660- it's hard to justify at the moment, considering I already have a Bosch table saw. If I have success with these projects, and start to make things regularly, I will probably go for it.
Start with a new and bigger shed ... there'll be no end to opportunities to make sawdust.I would love to get the Festool track saw, but at $660- it's hard to justify at the moment, considering I already have a Bosch table saw. If I have success with these projects, and start to make things regularly, I will probably go for it. Of course that eventually means getting the vacuum, router, orbital sander and table. I'm sure once you are used to Festool there's no going back.
I would use biscuits to join everything it you run the shelves horizontally and the dividers vertically the load will be transfer straight through the dividers, you won't need dados.
The Ikea one only has 6mm dowels supporting the edges so yours will be stronger.
I like the Hitachi M12V and the M8V both very cheap second-hand.
Pete
