TheFlash
Reiki Audio
Reiki Audio Limited announce Superswitch Master & Servant range
British startup Reiki Audio Limited is hoping to shake up the audiophile network switch market with its intriguing range of high performance audio-optimised Superswitch Master and Servant ethernet switches.
Designed, engineered and hand-assembled in England, all Superswitch models have the same smart and minimalist 3mm milled aluminium case with just 2 ports and no LEDs. The dual-shielded (copper-lined) Superswitch Master is for pre-streamer installation (including after an optical-electrical converter) and the Superswitch Servant, while a high performance network switch in its own right, is primarily intended to be installed post-router to separate an audio network from non-audio devices like computers and printers.
All Superswitch Masters and Servants are available in standard and Plus guises, the latter with a bundled iFi iPower PSU; PRO models with custom-designed linear PSU are available to order now for March-April delivery. Prices range from £649 for a standard Superswitch Servant to £2999 for a Master & Servant PRO bundle (2 switches and 2 linear PSUs). Check out the Which Switch tab at www.reikiaudio.com.
PM me, Fishies!
Exploded view of a Superswitch Master
Superswitch standard and Plus
Superswitch PRO
Superswitch Master & Servant bundle
Superswitch Master & Servant rear panels
PM me, Fishies!
Superswitch PRO
