The wax based stuff like that is great in the dry. However in the wet the first time the wheel picks up any water it coats the chain in grit all over again.Once you've got the chain spotlessly clean and dry use Squirt Lube on it overnight, wipe off in morning.
Ex bike shop mechanic and raced for 25 years, fecking hated every other chain lube
Yep, great for dry weather. Pointless in the wet.The wax based stuff like that is great in the dry. However in the wet the first time the wheel picks up any water it coats the chain in grit all over again.
You need to wipe the chain clean/squeaky clean the following day once it is dry, it should only be applied to the rollers where it will penetrate, there is zero benefit to coating links.The wax based stuff like that is great in the dry. However in the wet the first time the wheel picks up any water it coats the chain in grit all over again.
You reuse it until it is on the bike and removed by the rinsing process to drain. It's only a surfactant and the quantity used is about one lot of washing up.How should the degreaser be disposed of after use?
A MTBing mate of mine in the 90s used to swear by Fairy liquid. A good gloop on the chain, ride it up and down the street until everything was covered, then hose it off. A good rinse, reoil. This worked on mtbs after a winter ride when everything was under 2" of clag.Dawn dishwashing cleaner gets a few good reviews for chain cleaning. And is obviously safe. Never tried it, but my current cleaner has nearly run out, so will try it next (it’s only about £11 a bottle) so not expensive as a test. Reading more, don’t think it’s any different to Fairy
