This has changed direction - please see my post 31/12. The original was :
My pristine 1984 A60 is doing very nicely with single runs of well run-in Naim A4 cable to the speakers (where else). I don't want to touch the amp's innards (yet), but I would like to bi-wire.
Does anyone know of either a cable which would work well for the tweeters, with the A4 serving the bass/mids, or a cable which, used for both functions, would surpass that combination altogether ? Ideally such a cable would be < £10 per metre . IIRC LF signals travel 'inside' a conductor, while HF signals travel on the surface, so A4 should suit LF, but HF might prefer a lot of thin strands ?
Presumably the power amp section of another A60, or an SA60, could be fed and controlled by the pre-amp section of this A60, given suitable pre-out / power-in mods as per A60 A/P ? IIUC one power amp should drive the tweeters, and the other power amp should drive the bass/mids.
Anyone have a faulty / tatty A60 / SA60 going cheap ?
