I sort of adopt a 'vague logic' approach. Glass shelves ring when tapped. Some HiFi stuff does put out tiny vibrations, but I think that most of these are soaked up by the makers supplied feet. If not, it makes sense to me to put something under the kit responsible to keep these vibrations from getting into the glass, so sorbathane or etc seems sensible there. Now that the glass isn't 'ringing' from the kit, is it ringing from airborne or structural vibration? If that worries you then yes, some soft but elastic material between the shelf and the frame makes sense. Felt, cork, rubber, blu tac all would do well there at a guess. Now all you need worry about is what's happening where the floor touches the stand, but therin lies another tale.
