I am setting up a Benz Micro Glider (Series 2) Medium Output cart on my Origin Live Silver 2 arm and needed some advice.
Firstly, loading and gain on my Trichord Delphini phono. The recommended gain for the cart is 0.8mV and the loading 200 ohms
Unfortunately my Delphini only allows me to set the following loading:
33 ohms
100 ohms
1K ohms
And the following gain options:
0.25-0.4 mV
0.4 - 0.6 mV
2 - 3 mV
3 - 5 mV
So nothing really matches the 200 ohms / 0.8mV perfectly.
What's the closest settings I should try?
On a separate note, the tracking weight is also giving me a problem on the Origin Live arm. Recommended weight is around 2.0g, but I find that with the Origin Live counterweight, if I set tracking at 2.0 g, the arm swings out (even if I set anti skate to 0!!). I only get it to remain stable at 2.5/2.6g upwards.
The arm and anti skate are fine - I used it with a Denon DL103 (which is heavier than the BEnz at about 8.5-9g compared to the 6.8g Benz).
Is it OK to use the Benz with 2.6g tracking weight or does it mean I need to get a different counterweight for the Origin Live Silver arm?
It's all driving me a bit nuts at the moment! Any thoughts please?
33 ohms
100 ohms
1K ohms
0.25-0.4 mV
0.4 - 0.6 mV
2 - 3 mV
3 - 5 mV
