Later versions and releases were re-equalized in an attempt to remove surface noise from the 78 RPM acetates originally used to record the concert, with mixed results at best. This version is raw - surface noise and all. The recording quality, while not what we're used to, is explosively dynamic and amazingly extended in bandwidth. Your foot will tap.
