mandryka
I have many Logitech Media Server playlists which are mostly made of calls to tracks in Qobuz.
I am planning on ditching Qobuz and using Spotify, but I don’t want to lose the lists!
My plan is to edit them to make them Qobuz playlists, and then move them all to the Qobuz platform. I have worked out how to edit the m3u files and it works well enough (though not perfectly) using this online utility
https://www.tunemymusic.com/
Where I’m stuck is this: tunemymusic will only let me move one playlist at a time, I can’t set it up with all the playlists in a folder and tell it to transfer as a batch job. Does anyone have a solution?
The other problem is that, if I can make it work, I’ll end up with playlists in Spotify, rather than LMS playlists (which call Spotify) - and that’s not ideal for me.
