PigletsDad
My intelligence test came back negative.
1uF/10K gives 10ms time constant, 3dB rolloff at 16Hz.
Audible loss of deep bass. 30K should fix it.
Sussed it out now I think. I had C5=1uf/R5=10k now changed to C5=1uf/R5=30k.
Much better !
It maybe was answered aready
before: can I use the BC327/337 for Q2 and Q6?
There's no readily available replacements for the above diodes as far as I am aware. The diodes do ramp up the price of a B4, but it's still a very cheap pre amp for what you get.
istari_knight had surplus of the 1N5287/J501 not so long ago at a very good price, so well worth PMing him. I found some 1N5297/J505 going cheap from a UK supplier fairly recently, but iirc they may have been duff...I'll look into it. I order from Mouser fairly regularly, so I could always add some diodes (£4.60 each last time I ordered, now £5.14) to my order and forward them to you, if that helped.
Ouch.
I've just had a quick look at the jfet+resistor idea; based on teh datasheet for something available and cheap (the 2N5457, 60p at Rapid electronics) it looks like gate-source resistors of R=4K7 for 0.3mA out and R=820 for 1mA output is about right, and should maintain regulation down below 2V too, which is useful to the B4. Output impedance should be up around 500Kohms or more too - 'good enough' in other words.
